wireless wlc Thu, 08/09/2012 - 07:02
hi David,
  Did you manage to find a solution for this ? I have a similar requirement for using DNIS filtering for webauthentication and it doesnt seem to work.
Amjad Abdullah Thu, 08/09/2012 - 11:07
With webauth it does not work by default because the wlc does not send the ssid name in called-station-id attribute.
You need to configure
he wlc to send the ssid along with the ap mac address n that attribute.
Use this command on wlc cli:
config radius callStationIdType {ip_address, mac_address, ap_mac_address, ap_macaddr_ssid}
Use the last option: ap_macaddr_ssid
Hope this helps.
Trending Topics - Security & Network
