10-07-2007 04:49 AM - edited 03-03-2019 07:03 PM
Dears,
I have configured my switch 3560 but I cannot ping it?.. this switch has many connected devices for it and all of them I can ping it, it is strange.
I connected a camera and camera also I cannot ping it, below my SW configuration.
SW3650#sh run
Building configuration...
Current configuration : 1779 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname TARMAINSW-01
enable secret 5 $1$eASj$QhV.UVTtD97ntMXqeiuK90
enable password tarasol321
username pwtarasol password 0 tarasol321
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
duplex full
interface FastEthernet0/2
duplex full
interface FastEthernet0/3
duplex full
interface FastEthernet0/4
duplex full
interface FastEthernet0/5
duplex full
interface FastEthernet0/6
duplex full
interface FastEthernet0/7
duplex full
interface FastEthernet0/8
duplex full
interface FastEthernet0/9
duplex full
interface FastEthernet0/10
duplex full
interface FastEthernet0/11
duplex full
interface FastEthernet0/12
duplex full
interface FastEthernet0/13
duplex full
interface FastEthernet0/14
duplex full
interface FastEthernet0/15
duplex full
interface FastEthernet0/16
duplex full
interface FastEthernet0/17
duplex full
interface FastEthernet0/18
duplex full
interface FastEthernet0/19
duplex full
interface FastEthernet0/20
duplex full
interface FastEthernet0/21
duplex full
interface FastEthernet0/22
duplex full
interface FastEthernet0/23
duplex full
interface FastEthernet0/24
duplex full
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 55.55.55.1 255.255.255.192
ip classless
ip http server
snmp-server community public RO
control-plane
line con 0
line vty 0 4
password ttttttt
login
line vty 5 15
password ttttttt
login
monitor session 1 source interface Fa0/1 - 23
end
10-07-2007 05:58 AM
The configuration seems ok if you have all the devices in VLAN 1
From where are you trying to ping the switch?
what port is the camera connected to? Try changing the duplex settings to auto on that port
Narayan
10-07-2007 07:56 AM
tareq
I agree with Narayan that it would be very helpful to know where you are pinging from. Is it a device connected directly to one of the switch ports or is it connected through something else. Also what is the address of the machine that you are pinging from?
I notice that you have assigned address 55.55.55.1 to the switch VLAN interface with a mask of 255.255.255.192 which means that the range of addresses 55.55.55.2 through 55.55.55.62 should be able to communicate with the switch. Other addresses would not since the switch is not configured with a default gateway.
Rick
10-08-2007 12:11 AM
the camera is directly connected to the SW and i am trying to ping from other subnet 10.10.10.0/24
10-08-2007 12:34 AM
What is the ip address of the camera?
Seeing your switch configuration, you do not have a route to 10.10.10.0/24 network.
You need to set the default gateway on the switch.
Narayan
10-08-2007 05:45 AM
tareq
Where is the 10.10.10.0/24 subnet? All of the ports in the config are in VLAN 1. So is there a layer 3 device connected somewhere to provide routing between the subnets?
Rick
10-08-2007 06:14 AM
10-08-2007 10:57 AM
tareq
Thanks for the drawing that you posted. It does clarify some things and shows several misunderstandings or mistakes in setting up the network. The configuration that you posted shows all ports in the native VLAN and the drawing does not indicate anything different. However the drawing shows the switch as being in network 55.55.55/24 and the config is consistent with that. But the drawing also shows the server farm as being in 55.55.3/24. How can the server farm be in the same VLAN but be in a different subnet?
The drawing does confirm that you are attempting to ping from a remote destination using an address in 10.10.10/24. As we have pointed out more than once in this thread that the switch is not configured with a default gateway and because of this the switch will not be able to communicate with anything outside of 55.55.55. I also notice that while the drawing shows 55.55.55 as having mask of /24 the configuration of the switch shows the mask as being /26.
The fact that the switch does not have a default gateway does not explain why you can not ping the camera at 55.55.55.5. To find this problem the first thing would be to find out if the camera were configured with a default gateway and if so what is the address of the default gateway?
Rick
