connecting to nodes via (2) firewalls
Oct 7th, 2007
I have (2) networks I'm dealing with in this situation. NetworkA has firewallA (pix 515e) with computerA behind it. NetworkB has firewallB (asa5510) with computerB behind it. I successfully use a software VPN client on computerA to connect to firewallB. The problem I have after that is connecting to computerB from computerA via RDP.
If I replace firewallA with a linksys firewall, I can connect to computerB with no problem.
Any ideas why the pix515e would not let computerA connect to computerB but the linksys would?
mmrozek Mon, 10/08/2007 - 09:03
I should clarify that the cisco VPN client software on computerA successfully connects to firewallB, it just doesn't seem to pass traffic through it. Again, if I replace firewallA with a linksys, I can connect and pass traffic through the tunnel.
whisperwind Mon, 10/08/2007 - 10:22
sounds like the linksys has nat t turned on and firewall a does not....
mmrozek Tue, 10/09/2007 - 17:13
Thanks for responding whisperwind!
This is the config I have for NAT though:
global (outside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
I thought that was pretty standard but should I try something else?
If anyone has an article to recommend for this, I'd appreciate it. This seems to be a problem other people have but I'm not finding a clear answer.
