Banwidth limiting using QOS
Oct 7th, 2007
Is it possible to limit the bandwidth in different VLAn's using QOS..
i have 5MBPS internet connection ,with 254 public IP I did subnetting for this pool made separate vlan for each public subnet i have to share this connection in different VLAn's, ie is for different clients.. using one cisco 4506 switch.. For eg... for one client 256 kbps, the other one for 512 kbps..
Overall Rating: 5 (1 ratings)
Mohamed Sobair Sun, 10/07/2007 - 15:41
  • Gold, 750 points or more
You can configure Policing or Shaping whatever method you want to use at the SVI (The Vlan Interface itself) and limit ur bandwidth accordingly.
Mohamed Sobair
Mohamed Sobair Mon, 10/08/2007 - 01:40
here is a (Policing) example, assumed u are limiting the bandwidth at vlan 10 interface to 256Kbps:-
class-map match-any vlan10
match access-group 100
access-list 100 permit ip any any
policy-map vlan10 (Rate limited at 256Kbps)
class vlan10
police 256000000 32000 action transmit exceed action drop
int vlan 10
service-policy output vlan10
Mohamed Sobair
russ Mon, 10/08/2007 - 03:01
Is the police command correct? Should it not be:
police 256000 32000 action transmit exceed action drop
Mohamed Sobair Mon, 10/08/2007 - 05:26
Yes , you are right...
I think I have misatkenly typed it with extra 3 Zeros. Hence it in Bps , so it should be 256000.
Mohamed Sobair
