Port fowarding Cisco PIX 506E
Gilgameshan
Hello
I wan't opening up Port: 80, 8000, 8080 to internal 192.168.0.7 on the inside from the outside. It's to a DVR.
It's a Cisco PIX 506E.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ********** encrypted
passwd ********** encrypted
hostname CiscoPIX2
domain-name **********.local
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.1.0 Hassleholm
name 192.168.0.7 Kamera
object-group service Kamera tcp-udp
port-object range 8000 8000
port-object range 8080 8080
port-object range www www
access-list VPNClients_splitTunnelAcl permit ip any any
access-list inside_outbound_nat0_acl permit ip any 192.168.0.96 255.255.255.224
access-list inside_outbound_nat0_acl permit ip 192.168.0.0 255.255.255.0 Hassleholm 255.255.255.0
access-list outside_cryptomap_dyn_20 permit ip any 192.168.0.96 255.255.255.224
access-list outside_cryptomap_20 permit ip 192.168.0.0 255.255.255.0 Hassleholm 255.255.255.0
access-list Kamera permit tcp any interface outside object-group Kamera
pager lines 24
logging on
logging timestamp
logging console warnings
logging monitor warnings
logging buffered warnings
logging trap warnings
logging host inside 192.168.0.5
mtu outside 1500
mtu inside 1500
ip address outside ********** **********ip address inside 192.168.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool VPN 192.168.0.100-192.168.0.119
pdm location 192.168.0.5 255.255.255.255 inside
pdm location 192.168.0.0 255.255.255.0 inside
pdm location Hassleholm 255.255.255.0 inside
pdm location Hassleholm 255.255.255.0 outside
pdm location Kamera 255.255.255.255 inside
pdm location 0.0.0.0 255.255.255.255 inside
pdm logging warnings 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www Kamera www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 8080 Kamera 8080 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 8000 Kamera 8000 netmask 255.255.255.255 0 0
static (inside,outside) udp interface www Kamera www netmask 255.255.255.255 0 0
static (inside,outside) udp interface 8080 Kamera 8080 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 8000 Kamera 8000 netmask 255.255.255.255 0 0
access-group Kamera in interface outside
route outside 0.0.0.0 0.0.0.0 ********** 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 outside
http Hassleholm 255.255.255.0 inside
http 192.168.0.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
JORGE RODRIGUEZ
Level 10
Level 10
I would change kamera ACL with:
access-list outside_access_in permit tcp any interface outside object-group kamera
access-group outside_access_in in interface outside
or
access-list outside_access_in permit tcp any interface outside eq 80
access-list outside_access_in permit tcp any interface outside eq 8080
access-list outside_access_in permit tcp any interface outside eq 8000
access-group outside_in in interface outside
Jorge Rodriguez
Hello, thanks for the post.
I'am tied the first option you gave me. It dosen't work
I run sh access-list.
access-list outside_access_in; 3 elements
access-list outside_access_in line 1 permit tcp any interface outside object-group Kamera
access-list outside_access_in line 1 permit tcp any interface outside range 8000 8000 (hitcnt=0)
access-list outside_access_in line 1 permit tcp any interface outside range 8080 8080 (hitcnt=0)
access-list outside_access_in line 1 permit tcp any interface outside range www www (hitcnt=4)
//Thanks
Henrik
Henrik, it should have worked, is the internal server listening to these three tcp ports?
Looking at the port forwarding/redirect example the only thing I can think is using kamera local IP address in the static nat entries.
for sake of test could you use local ip .
static (inside,outside) tcp interface www 192.168.0.7 www netmask 255.255.255.255 0 0
http://www.cisco.com/warp/public/707/28.html#topic10
Jorge Rodriguez
