CCM 4.1 urgent help
The_guroo_2
Level 2
Level 2
Guys i have a v simple question but i cnat get my head around it.....i have a running environment (cluster) of call managers....now i want to relplicate it in my lab same topology....now i m using BARS as well....i have already build the call managers (in lab)...now i dont remenber the SQL passwords or other passwords for the live CCM cluster....now if i take a back up and put it in the lab will it work??? or the the passwords have to be same on lab to th elive environment......guys urgent help is needed.....reagrds
Zin.Karzazi
Level 5
Level 5
Recover your Password on the Productive Environment. Use the link below:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008073f593.shtml
Then build your Callmanager on your Lab with the same passwords as the prod. Use BARS and restore your config.
