Cisco VPN Client:can I keep one client binding one IP address?
Oct 7th, 2007
My router has configured Remote Access VPN,and it quote one ip address pool on the router.
Now,every time the same VPN Client connect to the router,it obtain different ip address.Each time ip addresss plus one(For example,this time the ip address obtained is,and netx time connected the ip address is so on.)
I want to binding the same VPN client with the same IP address. Can I archive this? How to configure? Pls help me,THS!
ivillegas Fri, 10/12/2007 - 06:28
If there are few users you can assign static ip address on Per user basis. Create VPN group for a particular user on the server and assign one IP address or You can use Address from Authentication Server option for IP assignment, the IP address should be provided by the radius server.
