distance commands parameter
Answered Question
Oct 7th, 2007
hi every body
i have a question regarding " distance"
command. here is the sample configuration
router ospf 1
network 10.0.0.0
distance 145 10.10.10.1 0.0.0.255 3
access-list 3 permit 2.0.0.0
in the above configuration " 10.10.10.1"
is router id supplying the routing information or the ip address of an interface supplying the information?
thanks
Correct Answer by royalblues about 9 years 3 months ago
For OSPF, the IP address and address mask entered for the distance command should match the source address and address mask of the OSPF router that sent the link-state advertisement (LSA).
The OSPF router would be the router ID
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Mon, 10/08/2007 - 00:27
Narayan
