ipv6 address short form
Answered Question
Oct 7th, 2007
hi every body
here is ipv6 address
2134:0000:1234:4567:2468:1236:2444:2106
can the above address be shortened as
2134::1234:4567:2468:1236:2444:2106
In one cisco book (ccnp bsci guide by catherine pacquet) it says consecutive zeroes field can be replaced by ::
but i read in different book by cisco
one or more than consecutive fields of zeros can be reduced by ::
now which one to believe
thanks a lot and have wonderful day!
Correct Answer by GillieLucent about 9 years 5 months ago
In your statement, 'one or more' represents 'one or more 16-bit group'
i.e.
0000 can be represented as :: , and
0000:0000 can also be represented as ::
See below for a brief explanation :
For eg. conside the below two addresses,
1080:0000:0000:0000:0008:0800:200C:417A
0000:0000:0000:0000:0000:0000:0A00:0001
In the above addresses, we do not need to write the leading zeros in each group of digits; for example, we can write
0 instead of 0000, 1 instead of 0001, 20 instead of 0020, and 300 insteadof 0300. If we apply this shortcut, the two preceding addresses become
1080:0:0:0:8:800:200C:417A
0:0:0:0:0:0:A00:1
A further simplification is represented by the symbol ::, which replaces a series of zeros. This method replaces zeros only when they fill a complete 16-bit group, and the double colon can be used only once in any given address.By applying this shortcut, the two preceding addresses become
1080::8:800:200C:417A
::A00:1
We make the assumption that the IPv6 address has a fixed length so that we can compute how many zeros have been omitted. This shortcut can be applied either to the center of the address (as in the case of the first address), or to the leading (as in the case of the second address) or trailing zeros.
In fact, the extended form of these addresses results in the following:
FF01:0:0:0:0:0:0:43 A multicast address
0:0:0:0:0:0:0:1 The loopback address
0:0:0:0:0:0:0:0 The unspecified address
They can be represented in compressed form as follows:
FF01::43 A multicast address
::1 The loopback address
:: The unspecified address
Vijaybabu
Overall Rating: 5 (1 ratings)
Mohamed Sobair Mon, 10/08/2007 - 02:17
  • Gold, 750 points or more
Consecutive fields Of Zeroes can be expressed with two colons, and you can Only do this once in a single IPv6 address; Example:
1234:1234:0000:0000:00000:00000:3434:3434
could be written as:
Zero Comp: 1234:1234::3434:3434
The Leading Zero Compression; in any field can be dropped but each block you do this must have at least on number remaining and that is if the block is all Zeros, this is a leading Zero Compression.
Example:
1234:0000:1234:0000:1234:0000:1234:0234
colud be written as:
Leading Zero Comp: 1234:0:1234:0:1234:0:1234:234
Mohamed Sobair
Correct Answer
GillieLucent Mon, 10/08/2007 - 04:17
i.e.
0:0:0:0:0:0:A00:1
::A00:1
Vijaybabu
