VPN problem between two ASAs after upgrading to 8.0
Oct 7th, 2007
After upgrading my asa devices (2*5510 and 5505) I started to getting odd messages which relate to lan-to-lan connection between these:
Oct 8 03:18:15 stasa1 %ASA-3-713227: IP = A.B.C.D, Rejecting new IPSec SA negotiation for peer D.C.B.A. A negotiation was already in progress for local
Proxy 192.168.0.0/255.255.224.0, remote Proxy 192.168.32.0/255.255.224.0
Oct 8 03:18:15 stasa1 %ASA-3-713902: Group = A.B.C.D, IP = A.B.C.D, QM FSM error (P2 struct &0xd8c23fc8, mess id 0x132546bb)!
Oct 8 03:18:15 stasa1 %ASA-3-713902: Group = A.B.C.D, IP = A.B.C.D, Removing peer from correlator table failed, no match!
At same time, users complain that their connections were reset. I think that there were no problems when we were running 7.2.
I wonder if there is something in the configuration I'll have to change after upgrade ?
ciscovertis Tue, 12/04/2007 - 06:11
We get the same errors after upgrading asa to 8.0(3) and asdm 6.0(3). Did you already solve the problemen?
AriSuutari Tue, 12/04/2007 - 22:16
Yes. We have two ASA boxes as fault tolerant pair. The solution was to power off both boxes at same time. After that, the problem was gone.
