Jon Marshall Sun, 10/07/2007 - 23:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
i don't believe this is your IOS, it is the ROMMON code.
Can you do a "dir flash:" from the enable prompt. That should show you IOS or
output from one of our 2800 routers
R6#sh ver
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1) <---- this is your IOS
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 26-Oct-05 08:42 by evmiller
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
R6 uptime is 4 days, 16 hours, 39 minutes
System returned to ROM by reload at 14:43:01 UTC Wed Oct 3 2007
System image file is "flash:c2801-ipbase-mz.124-1c.bin"
Cisco 2801 (revision 5.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ10082521
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Jon
