3560 uplink max. number switch
Oct 8th, 2007
Hi all,
I need to know if there is a limit to the number of 35xx switch linked in uplink each other in order to obtain a redundant solution (I use a typical yellow cisco cable to create this). I listen that this number is limited to 8, but I haven't found informations in the cisco website.
Thank you
Ale
royalblues Mon, 10/08/2007 - 01:34
Ale,
There is no restriction on the number of uplinks connected to a 3560 switch and is mainly dependent on the number of ports available.
in case you use fiber, then the uplinks are limited to 4 as there are only 4 SFP ports available
The one you are referring to is mostly the etherchannel between the swithces. In this case it is true that it is limited to 8 links.
Narayan
