[Pix] VPN Site To Site with Nat
Oct 8th, 2007
Hi all,
Can someone help me please
An inside server (192.168.92.6) need to access to a remote network 192.168.31.0.
A VPN site to site is established between Pix outside (192.168.111.6) and Multitech Firewall (192.168.111.200).
Now my inside server should connect to the remote network with this IP 172.20.20.6. So I have to Nat my inside server IP (192.168.92.6) to 172.20.20.6.
The remote network should connect to inside network by the 172.20.20.6.
My problem is I can establish a connexion to my inside network from the remote network but I cannot establish connexion (tcp) from my inside network to the remote network.
The weird thing is I can ping from both network each other.
This is my config below
access-list Outside_1_cryptomap extended permit ip 172.20.20.0 255.255.255.0 192.168.31.0 255.255.255.0
access-list Inside_nat_static extended permit ip host I92.168.92.6 192.168.31.0 255.255.255.0
static (Inside,Outside) Ip_172.20.20.6 access-list Inside_nat_static dns
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer 192.168.111.200
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
service-policy global_policy global
tunnel-group 192.168.111.200 type ipsec-l2l
tunnel-group 192.168.111.200 ipsec-attributes
pre-shared-key *
Thanks for answers
rmeans Fri, 10/12/2007 - 12:02
ACL Outside_1_crytpomap defines a class C network for 172.20.20.0/24. In your descriptions you talk about just one server (172.20.20.6). Do you have other hosts in the 172.20.20.0/24 network that need to traverse the VPN? Should acl Outside_1_cryptomap be permit ip host 172.20.20.6 192.168.31.0 255.255.255.0?
Keep in mind that VPNs need to match both sides. Is the Multitech defining a single host or a class C network?
Rick
