cs-mars 4.3.1 pnexp process abort
Oct 8th, 2007
Hi , during data export the process aborts with the following error:
Oct 8 11:37:10.605 2007@[email protected] 1024:START DATA EXPORTING...
Oct 8 11:37:10.605 2007@[email protected] 1024:Parameter: nfs_path = 10.24.9.153:/archivio/csmarsold/migration/nwmars01_2007-1
0-08-11-36-02
Oct 8 11:37:10.605 2007@[email protected] 1024:Parameter: event_start_time = 01/01/01:00
Oct 8 11:37:10.683 2007@[email protected] 1024:Trying to mount /mnt/pnarchive
Oct 8 11:37:12.127 2007@[email protected] 1024:EXPORTING REPORT RESULTS ...
Oct 8 11:37:12.127 2007@[email protected] 1024:Retrieving statistics of pn_report_result table...
Oct 8 11:37:12.141 2007@[email protected] 1026:Entering data mover thread
Oct 8 11:39:58.980 2007@[email protected] 1024:SQL exception caught while exporting report result data: ORA-01652: unable to
extend temp segment by 64 in tablespace TEMP
Oct 8 11:39:58.980 2007@[email protected] statement executed: select /*+ INDEX_DESC (pn_report_result_ie2) */ REPORT_ID, RUN_T
IME, BUCKET_SIZE, ITEM_RANK, ITEM_COUNT, ITEM_VALUE, ITEM_TYPE, ZONE_ID from pn_report_result where RUN_TIME >= :1 and RUN_T
IME <= :2 order by run_time desc
Oct 8 11:39:58.980 2007@[email protected] 1024:Total number of report result entries exported: 0
Oct 8 11:39:58.980 2007@[email protected] 1024:EXPORTING REPORT RESULTS FAILED!
Oct 8 11:39:58.980 2007@[email protected] 1024:PROGRAM ABORTS BECAUSE OF ERROR!
Any idea ?
michaelwoolfe Mon, 10/08/2007 - 11:38
If you can duplicate the error, can you post a copy of the sysstatus CLI command? I am interested in seeing your system resources. Check 'diskusage' and 'raidstatus' also.
r.spiandorello Tue, 10/09/2007 - 05:23
Hi, today the export finished successfully !
I think you cannot execute the pnexp the same day of the 4.3.1 upgrade.
During the night the system obtains the requirewd space
