lost appadmin psw-help
Oct 8th, 2007
we had ipcc express 5 integrated with CM6
the CM died yesterday and has since been rebuilt but I can't log into appadmin anymore. Whats the procedure to reset the password. in version 4 you use to be able to modify ccndir.ini but that file does not exists in version 5 :(
Overall Rating: 5 (1 ratings)
sbilgi Fri, 10/12/2007 - 09:18
You can run the CET tool, "Configuration Object Editor", from the command line. Once the CET opens go to the AppAdminSetupConfig container. Click your right mouse button the line in that container, and go to Properties. You then see a line that says, "Setup State: "DONE", Change the "DONE", to "FRESH_INSTALL", click ok and launch the AppAdmin page. Now you can log in with the ID Administrator, and the default password ciscocisco.
