IP Phone firmware upgrade..
Oct 8th, 2007
I have upgraded the cisco 7940/7960 IP phone firmware (using the file cmterm-7940-7960-sccp.8-0-7.exe) on the CCM, however when I checked the firware version on the IP phone its displaying the following..
App Load ID:
P0030301MFG2
Boot Load ID:
PC0303010200
Version:
3.1(MF.G2)
What does this mean.... has the phone firmware got upgraded or not??
can someone give ur inputs..
(Note: I'm trying the upgrade the IP phone firmware of 7940G IP phone on CCM with version 4.2.1)
Paolo Bevilacqua Mon, 10/08/2007 - 03:57
You can't go straight from 3.1 to 8.0 FW. You need to apply progressive upgrades as indicated the in FW release notes. I don't have the minimal sequence information but others should be able to to help :)
Also I believe that with CM 4.2.1 there is a recommend FW version you should use, again, not sure which one, sorry!
