Cisco OS 2000.2.7
Oct 8th, 2007
I try to install CCM 4.2, but i have upgrade the Cisco OS Version at 2000.4.2sr1 or later, when i try to install 2000.4.2 the installation fail, i have a 2000.2.4 cisco OS version and i need 2000.2.7 for the upgrade, but 2000.2.7 is not available on cisco.com
How to can upgrade the Cisco OS Version whitout this version?
Tim Smith Mon, 10/08/2007 - 10:10
  • Silver, 250 points or more
You typically need the media for this.
You need to go to the product upgrade tool - http://www.cisco.com/upgrade/
Then order the appropriate sw kit.
You could also try your local Cisco account manager.. but I dont know if they are allowed to distribute it.
Cheers,
Tim.
