CSA 5.2 Application Behaviour Analysis
Oct 8th, 2007
I am trying to start some application Behaviour Analysis. The problem is that the box with the application classes only has 3 classes in it.2 i have created and 1 preconfigured. I have at least 30 application classes configured. Does anyone know why i cannot see the rest of them? I have compared the classes and cant see any major differences.
tsteger1 Mon, 10/08/2007 - 11:02
  • Red, 2250 points or more
It looks like you should be able to choose any app class.
Did you create these application classes through the behavior investigation screen or through the App class screen?
If you create them through behavior investigation screen they show up in all app classes and the behavior investigation screen.
They also show up as app classes if you use the wizard to do an analysis.
Not sure if this is a bug or not but it looks like one.
Tom
c01642643287 Tue, 10/09/2007 - 02:16
I created most of the app classes through the app class screen. I may have to redo the classes through behaviour investigation.
tsteger1 Tue, 10/09/2007 - 09:09
Yep, that and the wizard seem to be the only way now.
I opened service request# 607026601 since it doesn't seem to work like it should.
Tom
