Get PIX Connections via SNMP
Oct 8th, 2007
Hello Experts!
Is there any way to query my PIX 515e to get a list of all it's current connections? I realize this could be ALOT, but if I get a trap that the connection upper-threshold has been reached, I would like to know what those connections are. Is there a way to do this via SNMP? Or any other way than logging in and doing a show conn? Thanks in advance!
Overall Rating: 5 (1 ratings)
amritpatek Fri, 10/12/2007 - 13:49
There is no SNMP message that can be used to define a upper threshold for the connections that can be used to check the connection status. You can use a script that can automatically login and check the connections on your device or you can use some network management software for this.
