Cisco7609 ? cannot configure the ports as ?switchport?
Oct 8th, 2007
After replacing a WS-X6548-GE-TX, I cannot configure the ports as ?switchport?:
swit(config)#interface gigabitEthernet 2/48
swit(config-if)#switchport
swit(config-if)#switchport mode access
Command rejected: Gi2/48 not a switching port.
If I change the slot it works, the problem just happens with slot 2. Before, it was working:
swit#sh startup-config | b 2/48
interface GigabitEthernet2/48
no ip address
speed 1000
switchport
switchport access vlan 500
spanning-tree portfast
The supervisor is a WS-X6K-S2U-MSFC2.
Thanks a lot,
Marcelo
glen.grant Mon, 10/08/2007 - 17:09
  • Purple, 4500 points or more
Try defaulting the interfACE and reinputting the info . Also "switchport" has to be the very first command.
conf t
default interface G2/48
m.carvalho Mon, 10/08/2007 - 20:15
I tried clearing the entire configuration module and did not work. I replaced the line card for a new one and did not work too.
Only with the version upgrade it worked.
Thanks a lot for your attention.
Marcelo
m.carvalho Mon, 10/08/2007 - 20:11
The problem was due a BUG in the version. With the upgrade it is working.
Old version: c6sup22-psv-mz.121-19.E1a
New version: c6sup22-psv-mz.121-27b.E3.bin
Marcelo
