Warning message
show the log in an ACL
Answered Question
Oct 8th, 2007
I have an ACL which is working fine.
150 deny ip any host 204.73.44.250
160 deny ip any host 204.73.44.226 (32 matches)
170 permit udp any 0.0.0.0 255.255.255.0 eq snmp
180 deny udp any any eq snmp (22 matches)
190 deny tcp any any eq 2967 log (7173566 matches)
200 deny tcp any any eq 6667 log
210 deny ip any host 66.176.202.133 log
220 deny ip any host 211.100.30.34 log
230 deny ip any host 211.100.19.116 log
240 permit ip any any (255731 matches)
Now what level do I set the logging trap at to get these transfered to my syslog server.
BTW, other items are being transfered, except the hits on the ACLs.
TIA, Stephen
Correct Answer by Richard Burts about 9 years 10 months ago
Stephen
The log output from an access list is severity level 6.
Rick
Overall Rating: 4.8 (3 ratings)
Edison Ortiz Mon, 10/08/2007 - 14:30
  • Hall of Fame,
    Founding Member
You won't get all the hits individually. You will get a sum of hits within a process interval.
In other words, if you are accessing port 6667 for 2 minutes, it will accumulate that amount of hits and when the process is finished, it will transfer that information over to the syslog server with the total count.
Please see:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_c/fcfprt3/fcf013.htm#wp1001168
Correct Answer
Richard Burts Mon, 10/08/2007 - 14:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Stephen
Rick
