Contact Center
Hi All,I wonder if any of you have increased the vRAM on your UCCE Rogers/Aw-HDS beyond the prescribed by OVA numbers? I.e. if Rogger is said to have 6GB by the OVA can I make it 8?  SQL is eating memory plus there is some other management and securi...
Engnr by Level 1
  • 86 Views
  • 2 replies
Hi, We have some scripts that send a call redirect to a user's voicemail greeting and this works fine, using the call redirect step (destination = VM pilot, Called address reset to user's Ext.).The current set up from CUCM to Unity is SCCP, and I've ...
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 166 Views
  • 3 replies
Greetings, Can you provide the URL and Body example to update a campaign via the Outbound API.  I am able to Create Campaign, Get Campaign Definition, Get Campaign Records, Import Campaign Records, Delete Campaign Records, and Delete Campaign, but th...
galguire by Level 4
  • 1006 Views
  • 5 replies
A customer reports that contact center agents sometimes get a 403 Forbidden when trying to log into the desktop. This error resolves itself on its own after around a few hours; without going deep into troubleshooting, can someone give me a few hints ...
pescla by Spotlight
  • 90 Views
  • 2 replies
Moving away from VXMLGW to VVB and I am curious about having multiple entries in the VVB host-to-ip configuration.   Today I have something like thismediaserver Datacenter1_ip1, Datacenter1_ip2mediaserver-backup Datacenter 2_ip1, Datacenter2_ip2 The ...
