BSR ( Bootstrap rouetr ) configuration
Oct 8th, 2007
I want to know about BSR configuration in a VRFlite scenario. As per my understanding I need to put two commands at the router which I want to make the BSR :
ip pim vrf Multi_2 bsr-candidate
ip pim vrf Multi_2 rp-candidate
and at rouetr ( connecetd to receiver ) I just need to enable pim sparse-mode.
Please suggest me , whether this config is ok or I need to cinfigure something else. if this is ok then I am facing a problem . I am not getting rp at receiver side.
Thanks in advance.
Regds,
Ashutosh
