LMS taking loopback IP from devices
Oct 8th, 2007
I am facing a problem with device discovery.It shows the loopback IP address of the devices instead i want to see the management IPs.Can anyone give a solution for this asap.
yjdabear Tue, 10/09/2007 - 04:32
  • Gold, 750 points or more
Do you have "Use LoopBack Address" checked under CM -> Admin -> Device Discovery -> Discovery Settings -> Preferred Management IP? If so, uncheck that and look again after the next discovery cycle.
Martin Ermel Tue, 10/09/2007 - 05:27
  • Blue, 1500 points or more
it is exactly what yjdabear wrote
and for devices being already discoverd you could change the Management IP in Campus Manager - Topology Services. Open a Network View, highlight a device and use the advanced menu (right mouse click) and go to 'Change Management IP...'
sachipanda Fri, 10/12/2007 - 16:19
Thanks buddy
This was the case.I unchecked it & it worked
