Danilo Dy Tue, 10/09/2007 - 05:13
  • Blue, 1500 points or more
If you have CCO account you can check your IOS vulnerabilities/bugs from the Bug Toolkit http://tools.cisco.com/Support/BugToolKit/
With or without vulnerabilities, without securing the IOS, your router can be accessed by unauthorized people or they can send DDOS top bring it down. To minimize/eliminate exposure to external threats especially if your router is an internet router, check the guidelines in these links;
http://www.cymru.com/Documents/secure-ios-template.html
http://www.nsa.gov/snac/
Check your router exposure to external threats by using Nessus the #1 vulnerability scanner (voted by both good and bad hackers).
http://www.nessus.org/download/index.php
For bugs, you can avoid it by not using the IOS feature that are affected by bugs if you don't need it. Best is to have a back to back maintenance for IOS update.
Dandy
