Multiple dial-peers for a single voice-port
Answered Question
Oct 9th, 2007
I know that you can configure multiple dial-peers for a single voice-port but it seems I'm not able to achieve the functionality I'm looking for.
We've got an E1 (primary rate - 30 channels) for connectivity to the PSTN which serves 100 MSNs, from "700" to "799".
What I'm looking to achieve is the selective routing of some MSNs to IP phones within a certain extension range and others to IP phones within another extension range.
For example, I want MSNs 713,751,776 to be translated to IP phones 813,851 and 876 respectively. The remaining MSNs are to be translated to IP phones in the 6xx range.
I've created two dial-peers for the same voice-port, each with a different "translation-profile" which aims to achieve the above but alas its not working...it always matches dial-peer 30:
dial-peer voice 28 pots
description INCOMING_DDI_8
translation-profile incoming incoming-did-8
preference 1
incoming called-number 7[0-9][0-9]
direct-inward-dial
port 0/2/1:15
dial-peer voice 30 pots
description INCOMING_LEG_DIALIN_6
translation-profile incoming incoming-did-6
preference 2
direct-inward-dial
port 0/2/1:15
Correct Answer by Paolo Bevilacqua about 9 years 4 months ago
You know, not to insinuate even more uncertainty, but I'm not even sure that 703 beats 7[0-9][0-9] on incoming DP ...
My take on doing things in tcl when regular config would do, is to look at the practical aspect of it. As long you can understand and handle the configuration approach, go with that.
Overall Rating: 4.3 (3 ratings)
Paolo Bevilacqua Tue, 10/09/2007 - 05:01
In you example, 30 is matched all the time because it has higher precedence and identical incoming called-number as 30.
But, how many translations do you need ? If less than 15 you can fit them all under a single voice translation-rule. And if you can work by patterns, even less rules will be necessary.
Note: you don't need to configure port for incoming DP. The port statement is ignore as you will see trying a wrong port or none at all.
jaimeatnok Tue, 10/09/2007 - 05:18
Unfortunately more than 15 or else a single translation-profile would be enough: 14 individual rules + 1 general rule for the remaining MSNs.
I thought DP 28 had a higher precedence than DP 30...hmmm, in fact does this means that a DP with a higher number has a higher precedence?
Paolo Bevilacqua Tue, 10/09/2007 - 05:32
Ok for the rules, anyway from you previous example, it seemed that some rule can be grouped in patterns.
Tag ID of the DP has no significance in precedence: if you want them to match correctly called number, configure appropriately as "incoming called-number".
as a recognition to those providing answers, please rate useful posts using the scrollbox below!
jaimeatnok Tue, 10/09/2007 - 05:36
Ok, thanks :)
But how can DP 28 be given a higher precedence than DP 30?
As you can see I'm using the "preference" command but I don't think its having any effect.
jaimeatnok Tue, 10/09/2007 - 08:32
I've swapped both dial-peers to obtain the functionality I need but I'm still clueless as to why one has a higher precedence than another even though I've got the "priority" command set.
Paolo Bevilacqua Tue, 10/09/2007 - 09:27
I may need to correct my previous statement about preference because as in your case, the truth could be that the preference statement is ignored on incoming DP so the "winner" is selected unpredictably.
If it is like that it would still make sense because these are incoming DP and would not make sense to have a "preference" in presence of identical "incoming called-number" like you had.
Instead for outgoing DP that can have up/down state, different routing, etc, it makes sense that the preference works as configured.
Well one thing you could do is...
preference 1
incoming called-number 7..
direct-inward-dial
port 0/2/1:15
preference 1
incoming called-number 751
direct-inward-dial
port 0/2/1:15
By doing this you would have a catch-all to match your primary translation profile and then specific route patterns for excess numbers that couldn't fit in your translation list.
You really want to try and avoid using multiple exact match dial-peers unless you have a really good reason.
And of course you could just set up translation patterns CM as well for the overflow.
just though i would chime in on the preference thing and some good docs...
the default preference is
preference 0
and the lower the preference the higher priority it will have.
Here are some good docs to read over just to get a feel for what is happening and the way it is supposed to work.
Understanding Inbound and Outbound Dial Peers Matching on IOS Platforms
http://www.cisco.com/warp/public/788/voip/in_dial_peer_match.html
Understanding Inbound and Outbound Dial Peers on Cisco IOS Platforms
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080147524.shtml
Configuring Dial Plans, Dial Peers, and Digit Manipulation
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080aec.html
I think these docs will help.
Mike
Paolo Bevilacqua Tue, 10/09/2007 - 16:05
Mike, thanks but the doubt that is taking me now, as mentioned above, is that "preference" only works for outgoing DP. The docs don't mention that explicitly. I shall test and report.
yea, i am not 100% sure about the inbound dialing, it is starting to sound like you are going to need a lot of dial-peers with unique incoming called-number statements to achieve what you want. you should not have to create a translation profile for each dial-peer however you will just need to track which translation profiles will contain the rules to translate each DID you want to manipulate and assign it to the appropriate dial-peer.
jaimeatnok Wed, 10/10/2007 - 01:35
Thanks for the replies!
From the tests I've done it doesn't seem "preference X" has any effect on incoming DP at all.
I see what you mean with regard to the need for many incoming DPs to achieve what I want. Correct me if I'm wrong (I could well be as I've come from the data world and have had to learn voice "things" pretty fast!) but if I were to have a DP with "incoming called-number 703" and another with "incoming called-number 7[0-9][0-9]", the former (703) would have a higher preference for matching than the latter (7[0-9][0-9]), correct?
At the moment I've switched the DP and it works but I can see this is a very very fine balance and precarious situation...
Would using a TCL script be a better approach?
Correct Answer
Paolo Bevilacqua Wed, 10/10/2007 - 10:49
dgrosskopf Fri, 10/12/2007 - 08:25
Try changing your incoming called-number to a more specific pattern.
sandeep pokhriyal Sat, 10/13/2007 - 10:30
hi you can also use secondary number.
keep the secondary number the last four digits or whatever you are receiving from your telco.
and make a dial-peer accordingly.
