10-09-2007 05:21 AM - edited 03-15-2019 06:53 AM
Hello all! I have a strange problem - wrong time displayed on my phone when I used +5 GTM timezone (Ekat). It is correct time on server (right time and GTM), but not on the phone (-1 hour for real time). I tryed another timezone (+6 - gived me +2 hours for real time, +5.30 - gived -30 min for real time).
10-15-2007 11:12 AM
Do you have any Day light settings configured for your CCM server.
Also verify this bug details:.CSCdz49110
10-15-2007 11:21 AM
Is the phone in correct Device Pool?
04-01-2008 12:56 PM
I am having exact same issue. Any solution yet?
04-01-2008 05:07 PM
We have the same issue but here's what we did!
1st check this link for the bugs:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008093315c.shtml
If the manual update of the time didn't fixed the problem, then do this.
Go into database type timezone table and change this as below:
From set the "stddate" and "dstdate" to "0/3/0/5,2:0:0:0"
and "0/10/0/5,2:0:0:0"
to
set the "stddate" and "dstdate" to "0/4/0/1,2:0:0:0"
and "0/10/0/1,2:0:0:0"
i.e. 0/4/0/1,2:0:0:0 means 4=month, 1=1st week.
It depends on your CM version (ours is 4.1(3), etc..but this work on our side so it's your own risk if you do this...
also we have to upgrade our 7941s to the latest 8.3(4)sr1 3
just sharing...
tnx
04-01-2008 06:31 PM
I'm running CUCM 6.0.1 and changed to sync with a NTP source instead of the CUCM servers. We ended up using the Cisco switch, as the network NTP source wouldn't work.
When DST changed all the phones had the correct time!!! Email was off by an hour, our front door wouldn't open, but the phone were correct.
