SCA Reporter stays "please wait, initializing templates..."
Answered Question
Oct 9th, 2007
Hello I don't know if this is the correct place for this conversation, but here it goes.
I have SCA Reporter Version 3.1.0.11 and SCA BB Console Version: 3.1.0 and in both the Windows -> Preferences -> Reporter -> Templates option never loads the templates so I cannot configure the settings for it to work. At first I thought it was a Java issue, but I see that the software runs with its own java virtual machine. Any Ideas?
The database connection is established but since I cannot configure the SCE IP I cannot run any report.
Correct Answer by blagoy.popov about 9 years 2 months ago
Check /etc/hosts file on the CM. You should have there line for the cm hostname. Like This:
If you have this and still you have got problems then run 'dbtables.py -a' on the CM and check that you have 'CONF_SE_TZ_OFFSET'. If the CONF_SE_TZ_OFFSET is missing , then you probably forgot to run ~/cm/bin/jselect-sce-tz.sh. Run it and then remove the db in the reporter and add it again. Be sure to both activate the db and also apply.
BR and hope this helps
Overall Rating: 5 (2 ratings)
Correct Answer
blagoy.popov Fri, 10/26/2007 - 09:32
