What is the shortes connection over fiber (trunk between two CAT2950-SX)
Answered Question
Oct 9th, 2007
Hi all
I have to build a trunk connection between two 2950-SX (over fiber).
The trunk connection is a MTRJ-MTRJ fiber cable.
Does it work, when the MTRJ-MTRJ cable has only a length of 2m.
(Both devices are in the same place).
Norbert
Correct Answer by Danilo Dy about 9 years 8 months ago
The minimum fibre patch cable length is 1meter. 2meters should work
Dandy
Overall Rating: 5 (2 ratings)
Correct Answer
Danilo Dy Tue, 10/09/2007 - 05:54
  • Blue, 1500 points or more
Dandy
