EAP-FAST PAC file
Oct 9th, 2007
I have an expired PAC on a customer's laptop that needs deleting (manually).
Trouble is, I can't find where it's stored on the customer's laptop. I have done a search for *.pac but it has come up blank.
Can anyone enlighten me?
MARTIN.
drolemc Mon, 10/15/2007 - 11:14
Open the ADU, click on profile Management and then Modify the EAP-Fast profile. Click on security > configure, and then select more next to the PAC Authority. Click on Global and now you should be able to see the PAC file below. Select it and then click on delete.
Trending Topics - Security & Network
