Jagdeep Gambhir Tue, 10/09/2007 - 06:55
  • Red, 2250 points or more
Hi Ed,
The command "switchport port-security limit rate invalid-source-mac" limits invalid source MAC address on a security port based on the pps (packets per second) value you configure
The default value is 10 pps. For example the below would limit packets from invalid source
MAC address to 100 pps
swithport port-security limit rate invalid-source-mac 100
If you would like to verify, you may try setting the pps to '0' in which case the switch would deny all invalid source MAC address packet.
~JG
