how to disable show commands
azmath.hk
We are having problem in disabling most of the show commands locally using AAA on router
Please review the config and let me know what is the way to disable all show commands except show ip int bri.....
Below is the config:-
privilege exec all level 7 crypto
privilege exec all level 7 release
privilege exec all level 7 renew
privilege exec all level 7 tclquit
privilege exec all level 7 access-enable
privilege exec all level 7 webvpn
privilege exec all level 7 ssh
privilege exec all level 7 x28
privilege exec all level 7 x3
privilege exec all level 7 pad
privilege exec all level 7 mtrace
privilege exec all level 7 msta
username admin privilege 15 password xxx
username rem privilege 15 secret xxx
username user1 password xxx
aaa authentication login default local
aaa authorization exec default local
I was able to do it. Here is the configs
AAASWITCH(config)#username jag privilege 7 password xxxxx
AAASWITCH(config)#privilege exec level 8 show running
AAASWITCH(config)#privilege exec level 8 show ver
AAASWITCH(config)#privilege exec level 6 show ip interface brief
AAASWITCH(config)#privilege exec level 8 show user
Results
Username: jag
Password:
AAASWITCH#show run
% Invalid input detected at '^' marker.
AAASWITCH#show ver
AAASWITCH#show ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
Vlan1 192.168.26.4 YES NVRAM up up
Vlan2 unassigned YES NVRAM administratively down down
Vlan22 192.166.22.5 YES NVRAM administratively down down
Vlan30 unassigned YES NVRAM administratively down down
AAASWITCH#show users
AAASWITCH#show user
In this way you need to set priv for all possible show commands.
If user priv is 2 then set priv for show commands more then 2.
Hope that helps
~JG
5 Replies 5
azmath.hk
Please help me on this
You need to set priv lvl of all show commands,
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
~JG
I tried so many ways but still no go.
Please suggest me the configuration in which privilege level2 user dont see show commands in user mode except show ip int bri
Thanks in advance for the help u will provide
Results
Username: jag
Password:
AAASWITCH#show run
AAASWITCH#show ver
ocol
AAASWITCH#show user
Hope that helps
~JG
Thank you so much for your help its working now.
