UC500 directory lookup problem
Oct 9th, 2007
I've installed a UC520. Now we've a problem with the directory lookup. When a external number exist in the directory, the name is not presented in the display when a call arrives from that external number. When I make the same configuration on a CME the name will be presented.
What can be the problem? Is this an UC500 issue?
Greets Niels
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Tue, 10/09/2007 - 07:14
Do you have
service dnis dir-lookup
under telephony-service ?
hope this helps, please rate post if it does!
Daniel Leonard ... Tue, 10/09/2007 - 22:05
Yes, I always configure that setting.
This is the telephony-service configuration, I only changed the phone number :)
max-ephones 8
max-dn 10
ip source-address port 2000
auto assign 1 to 10
service dnis overlay
service dss
user-locale NL
user-locale 1 NL
user-locale 2 NL
user-locale 3 NL
user-locale 4 NL
network-locale NL
network-locale 1 NL
network-locale 2 NL
network-locale 3 NL
network-locale 4 NL
max-conferences 4 gain -6
transfer-system full-consult
directory entry 1 00553333333 name test
anderson-david Wed, 10/10/2007 - 00:06
Hi Niels,
I know it might sound silly but does the incoming CLi on the number match the number in your directory? it could be that the number is not matching correctly, run a debug and see what the incoming number is
I hope this helps
Daniel Leonard ... Wed, 10/10/2007 - 01:20
Hi Dave,
Yes, I'm realy sure. The incoming number matches the directory entry. When I made the same configuration on a CME everything works fine. I've this problem only on the UC500.
Paolo Bevilacqua Wed, 10/10/2007 - 01:28
Then I'm afraid you will need to log a case with the TAC. Consider that UC520 has newer IOS so the possibility of bugs is always there.
davieshuw Thu, 10/11/2007 - 05:54
Hi, ive just tried doing this on my UC520.. and I get the same issue. Id be interested to know if the case is looked at by Cisco...
Hang on though.. It only seems to work when I do a group pickup. It displays the correct name from the directory, but it doesnt display on the phone the call was intended for.
Paolo Bevilacqua Thu, 10/11/2007 - 09:00
Which exact IOS are you running on the UC520? Can you upgrade to 12.4(11)XW4 and try again ?
davieshuw Thu, 10/11/2007 - 09:11
to be honest im not sure, i'll take a look tomorrow when I get to the office
Paolo Bevilacqua Mon, 10/15/2007 - 01:57
Now you can tell that it appears to be a bug in the latest version and you should log the problem with the TAC.
