Changing inactive Timeout on CSS
pmajumder
Level 3
Level 3
Can the inactive timeout be changed on a content switch running v8.10.2.05 without impacting current sessions, or will I be required to suspend the content rule to prevent disruption and/or required for the change to take effect?
Pradeep
Pradeep,
you can change it without suspending the content rule.
CSS11503-2(config-owner-content[gdufour-WWW])# sticky-inact-timeout 6
CSS11503-2(config-owner-content[gdufour-WWW])# acti
%% Content rule is already active
CSS11503-2(config-owner-content[gdufour-WWW])# sticky-inact-timeout 8
Be aware that the timeout will only be applied to new entries. So existing entries will timeout with the current idle timeout.
Gilles.
Gilles Dufour
the only way to change the idle timeout is the command 'flow-timeout-multiplier ' which does require you to suspend the content rule.
CSS11503-2(config-owner-content[gdufour-WWW])# flow-timeout-multiplier 4
%% Attribute may not be modified on active rule
Gilles.
Giles,
Sorry, I wasn't clear, but I am talking about the sticky timeout - "sticky-inact-timeout x"
I have it as follows:
content Agents-Prod
vip address x.x.x.x
protocol tcp
port 80
balance weightedrr
add service Agents1-Prod
add service Agents2-Prod
add service Agents3-Prod
primarySorryServer Agents-ProdSorry
redundant-index 64
advanced-balance sticky-srcip
active
Pradeep
Pradeep,
Gilles.
Thank you Giles!
Pradeep
