can not add static arp entry on ACE context
Answered Question
Oct 9th, 2007
I am trying to make a static arp entry on a context on a cisco ACE.
However i get
"% invalid parameter detected at '^' marker."
The command i am using is "arp 172.30.6.4 02.bg.ac.1e.06.04"
The ^ is located at start of the mac address entry.
What could be wrong ? Is this a bug ?
Correct Answer by Gilles Dufour about 9 years 8 months ago
bg is not a valid hex value only letters from a to f are correct.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Tue, 10/09/2007 - 08:12
  • Cisco Employee,
Gilles.
sebastianvandijk Wed, 10/10/2007 - 00:11
Hi Gilles,
It seems i have to get myself a new pair of glasses... ;)
tnx ! this solved the problem.
sebastianvandijk Wed, 10/10/2007 - 04:54
Now i want to replace the address with 03.bf.ac.1e.06.04.
Again i get some error, this mac address is not accepted ?
ACE-acc-01/CONTEXT1(config)# arp 172.30.6.4 03.bf.ac.1e.06.04
Error: Invalid MAC address
Gilles Dufour Wed, 10/10/2007 - 15:10
  • Cisco Employee,
the 03 indicates this is a multicast mac addresss. [everything with the first bit set in the first bytes is multicast].
The ACE module currently does not support those type of mac addresseses.
Gilles.
