BGP Attributes
Answered Question
Oct 9th, 2007
  • Cisco Employee,
Hi All,
I did some lab on manipulating the BGP route selection using the various attributes. I observed a behavior that after changing the attributes and applying the route-maps to the neighbor, still the routes didnt get change in the RIB and the BGP table. Its only when I reset the BGP peer or bring the interface down, it gets reflected in the BGP and RIB tables. Is it the correct behaviour. My concerned is imagine if its a production network and bringing the peer relationship down might have very adverse effect on the whole routing domain.
-amit singh
Correct Answer by paul.matthews about 9 years 6 months ago
it is correct - look up soft reset.
Paul.
Overall Rating: 3 (1 ratings)
Correct Answer
paul.matthews Tue, 10/09/2007 - 08:14
  • Silver, 250 points or more
Paul.
Amit Singh Tue, 10/09/2007 - 08:18
  • Cisco Employee,
Paul,
Thanks got the answer. That's why we have the in/out soft reset of the neighbors for the local policy engine calculation.
-amit singh
gaurav_thapar79 Tue, 10/09/2007 - 09:59
Sometimes it requires a soft reset of BGP peer despite configuring soft reconfiguration inbound/outbound.
In your case, the change in routing policy & change in attributes shall take 180sec to update the BGP peer RIBs n routing table. The impact wld be seen after that only
