Warning message
CCM4.1.3 Meet-Me Error "Exceeded Bandwidth"
Oct 9th, 2007
Recieve error on Meet-Me Conference after 7 participants. Max Conferences is set to 10 in enterprise parameters for Cisco Call manager. Anyone know why we are getting this error?
this is a location issues, you probably have devices in different locations connecting to the meet-me number. what location is the phone in that you are starting the meet-me from? check the bandwidth defined for that location under "System - Location".
If all the phones are at the same location, you should not see these errors however if you have phones that are connecting to this meet-me that are set to a different location, then you need to determine what codec you are using for the meet-me, what is your actual available bandwith at each site and verify the phones are using the correct location setting.
hope this helps.
Mike
TODD BERGMAN Tue, 10/09/2007 - 16:40
Yes thanks...forgot about that...
Thanks for your time to reply.
