Unity fax id number question
red73mustang
I may already know the answer to this, but is there a waiting period that needs to pass before I can edit the fax id number in Unity due to the Exchange propegation period for recently created accounts?
Thanks, Chet
red73mustang
I figured it out. Fax ID number must 1st be typed in "Telephones" tab for Active Directory and then you have to copy and paste it into the Fax ID field for Unity. If you try and type the number in Unity you will get errors re: illegal carachter (spaces, -) Don't know why.
Chet
