10-09-2007 09:41 AM - edited 03-15-2019 06:53 AM
I'm trying to connect an analogic fax through an ATA. The gateway is in MGCP mode with SRST. If I can use the fax like a phone but I can receive/send fax with it.
I'm attaching the sh run file of gateway, and prserv file with ATA debug.
Someone can help me??
Thanks in Advance
Sucr
10-09-2007 01:38 PM
here is a copy of mine.
mgcp
mgcp call-agent 192.168.1.19 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
10-09-2007 03:19 PM
i think the command that is messing you up is the
mgcp fax t38 force
ATA's do not support t.38 fax-relay for faxing and you need to disable this.
This will disable t.38 fax-relay on a mgcp gateway.
