LWAPP CLI Command Q?
Overall Rating: 5 (2 ratings)
Rob Huffman Tue, 10/09/2007 - 15:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Pre-stage Configuration for LWAPP Access Points
This feature simplifies the deployment of LWAPP access points in remote locations by adding a new set of CLI's to the Recovery IOS image. The static IP address, Netmask, Default gateway, and Primary Controller IP address may now be configured on the access point. Configuring the Primary Controller IP address will help the access point discover and register a specific Controller over the WAN links. In a deployment scenario where a DHCP server is not available in remote locations the CLIs may be used to configure the static IP address and the initial LWAPP controller information.
The new pre-stage CLI commands are listed and described in Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode. Click this link to browse to that document:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
Configuring Static Parameters to Register the Access Point to a Controller
Using the password that the controller sent to the access point, enter into EXEC mode on the access point console. When the access point is running LWAPP or a recovery IOS image, you can configure the static IP address on the access point, the IP address on the controller, the access point hostname, and the default gateway IP address by entering these commands:
lwapp ap ip address ip-addr subnet-mask
**lwapp ap controller ip address ip-addr
lwapp ap hostname ap-hostname
lwapp ap ip default-gateway ip-addr
The access point with a recovery IOS image uses the static controller IP address to register to the specified controller and download the current LWAPP image. After the access point successfully registers to the controller, it receives configurations from the controller. The access point static hostname and the IP address of the controller are deleted from the access point configuration file. However, the access point static IP address and the netmask and the default gateway IP address are not deleted.
When the access point is running a recovery IOS image, the commands to configure the static IP address on the access point, the IP address on the controller, the access point hostname, and the default gateway IP address are always enabled.
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
