network-object command
Oct 9th, 2007
all, I need to restrict IP addresses : 10.220.4.1 - 4.48 from getting out to the internet, IP address 10.220.4.49, I would like access to the internet. Using the: network-object 10.220.4.0 255.255.255.0 command, how can I restrict the IPs up through 48, but allow 49?
Jon Marshall Tue, 10/09/2007 - 11:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Presumably you are talking about pix/asa device.
If you just need to allow .49 then just allow that host only in the access-list ie.
access-list outbound permit tcp host 10.220.4.49 any eq 80
etc...
However if you would like to allow all the 10.220.4.0/24 network other than IP addresses 1 -> 48 which i think is what you are asking
LabProtect1(config)# object-group network test
LabProtect1(config-network)# network-object 10.220.4.0 255.255.255.224
LabProtect1(config-network)# network-object 10.220.4.32 255.255.255.240
LabProtect1(config)# access-list outbound deny ip object-group TEST any
LabProtect1(config)# access-list outbound permit ip 10.224.4.0 255.255.255.0 any
Jon
