RSTP convergence time
What is the default convergence times when using RSTP? Unlike STP I understand that RSTP has three timing intervals before it begans to converge.
RSTP
Hello timer >>> 2 seconds
MAX-AGE >>> 6 seconds
Forward-Delay (Learning) >>> ? seconds
Default convergence time ?
STP
MAX-AGE >>> 20 seconds
Forward-Delay (Listening) >>> 15 seconds
Forward-Delay (Learning) >>> 15 seconds
Default convergence time 50 seconds
If I am understanding things correctly
1. The Hello interval are the same as STP which is every 2 seconds.
2. The default Max-Age time for RSTP is 3 times the hello interval or 6 seconds.
3.RSTP elminates the listening state however, there is a learning state.
What is the default time that RSTP stays in the learning state before is transitions to either forwarding or discarding?
I can't seem to find this information.
Francois Tallet Tue, 10/09/2007 - 13:03
  • Gold, 750 points or more
Same value as for STP. But in the case of RSTP, those timers are only used as a fallback mechanism, if the proposal agreement mechanism (which does not depend on *any* timer) cannot work for some reason (neighbor not running RSTP, shared segment etc...)
Francois
