MGX 8850 RPM_PR slave to AXSM master cross connect
Oct 9th, 2007
While creating the master end of a cross connect between a RPM_PR & AXSM I am getting the following error:
addcon 8 0 50 5 1 -slave 4700918100000000016444472000000107730100.0.50 -lpcr 4000 -rpcr 4000 -lscr 4
000 -rscr 4000
ERR: Error in traffic parameters (dcmp)
The RPM sub interface configuration is:
interface Switch1.1 point-to-point
description Cross connect to AXSM
ip address 192.168.1.1 255.255.255.252
no ip route-cache
pvc 0/50
oam-pvc manage
encapsulation aal5snap
switch connection vcc 0 50 master remote
pcr 4000
scr 4000
rpcr 4000
rscr 4000
I am not sure why I am getting this error, can anyone help with this?
htarra Mon, 10/15/2007 - 13:46
  • Bronze, 100 points or more
It appears that the PNNI and AXSM DBs are out of synch. Could you please do ----- "dspcon 12:2.1:9 15 148" , on the PXM
and check if this connection exists ?
antione-smith Mon, 10/15/2007 - 15:00
I am not sure which connection you are referring to, but the problem I was having was a result of a missing statement.
no ip route-cache
pvc 0/50
vbr-nrt 1696 1696 100 <-- was missing
oam-pvc manage
encapsulation aal5mux ip
switch connection vcc 0 50 master local raddr xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
pcr 4000
scr 4000
rpcr 4000
rscr 4000
rmbs 100
The question I have now is: what PVC encapsulation type should I use on this subinterface to terminate a PVC coming from FRSM configured for frame forwarding?
I am currently using aal5mux ip but the PVC is showing failed.
rajput_p Tue, 10/16/2007 - 00:57
Hi Smith
Please try this one
addcon if vpi vci NSAP -lpcr -rpcr -lscr -rscr -lmbs -rmbs
regards
pawan
econneely Thu, 10/25/2007 - 03:33
A couple of things...
On the AXSM you set the Service Type = 5 nrt-VBR.1, however on the RPM you have not set the corresponding parameter. Example IOS command in PVC config mode is:
vbr-nrt
If you do not set the QoS param on the RPM, it will default to UBR with 100% PCR bandwidth, hence "error in traffic parameters" which refers to both the QoS value and the Cell Rates.
If you select vbr-nrt on the RPM the corresponding AXSM QoS is nrt-vbr.3 - option 7.
Be sure to match the cell rates exactly. Cell rates entered in PVC config mode are Kbps for output-PCR and output-SCR and cells for output-MBS.
Values entered in switch conn config mode are cells!
