ICnd help
Oct 9th, 2007
Hi all,
silly question probably, just taken the icnd and failed probably due not completing the simulators.
my question is according to icnd exam critea
Configure IP addresses, subnet masks, and gateway addresses on routers and hosts
refering to configuring hosts i take it it is ment u will have to configure a simulated workstation.
can some one hit me with the clue stick i dont want to mess up the exam.
am taking it next monday replies greatly appreaciated.
ellis_b Tue, 10/09/2007 - 21:21
go and buy a couple of routers and a switch or two. even a couple of 2501s would be great for you to practice on.
are you looking for sample configurations? i'm having a hard time truely deciphering what you are trying to ask.
Brad Ellis
CCIE#5796 (R&S / Security)
CCSI# 30482
CEO / President
CCBOOTCAMP - A Cisco Sponsored Organization (SO)
Email: [email protected]
Toll Free: 877-654-2243
Direct: +1-702-968-5100 = Outside the USA
FAX: +1-702-446-8012
YES! We take Cisco Learning Credits!
Training And Remote Racks: http://www.ccbootcamp.com
Routing and Switching Forums: http://www.routerie.com
Security Forums: http://www.securityie.com
Voice Forums: http://www.voiceie.com
mundo1234 Wed, 10/10/2007 - 02:55
Hi and thanks for the reply,
basically what i am saying is that
part of the icnd creteria is to configure ip address, subnet masks and gateway address on routers and hosts.
so for example say i get a simulation asking me to do just that.
what is being emplied by when refering to hosts
hope that helps.
mark.j.hodge Wed, 10/10/2007 - 05:37
You will get questions such as
Which of the following IP addresses are not in the same subnet as, mask
If mask were used with a class C network, how many subnets could exist, with how many hosts per subnet.
You will not be asked to configure IP addresses on a host, as the method is different depending upon the operating system. You will be expected to be able to determine if the host IP address, mask and gateway are appropriate for the network.
ellis_b Wed, 10/10/2007 - 06:37
when they use the word "host" they are referring to a computer (be it a server or workstation - but typically, it means a workstation, ie a PC).
ellis_b Wed, 10/10/2007 - 07:03
please explain. i really dont understand what you are asking.
mundo1234 Wed, 10/10/2007 - 08:19
basically i had simulator asking me to
cofigure a network.
ip address scheme rip network statments
clocking etc, the question also ask to configure the hosts default gateway.
is it safe to assume they are refering to the e0 interface (router port) as the defualt gateway witch a host is connected and not configure the host it self.
its was just i was unsure as to what was being asked, very limited info provided on sim
does that help
ellis_b Wed, 10/10/2007 - 08:50
okay, i think i understand you. you thought the sim was asking you to configure the host itself, correct? if so, then you misread the problem. i believe they just wanted the router configured for the proper default gateway that is acting as the default gateway for the host. make sense?
mundo1234 Thu, 10/11/2007 - 00:52
i see, it was 8.30 am when i took the test!
my fault really.
thanks for that i just wanted to be sure for next time.
the exam is hardly generous with its time it gives you!
Thanks People.
