I want to configure a dynamic default route
Oct 9th, 2007
I have a remote site with an ASA to the internet. It will have a default route pointing to that ASA. However, if the ASA (locally attached via a switch) dies, I want the remote site to learn a new default route from another site site with an ASA connecting to the internet. My routing protocol will be OSPF in a single area 0. IS there a way for a router to PING (via saa probes, or something similar) to determine whether to install it's default route into the routing table? What is the easiest way to do this? (Have a default route dependent on whether the next hop address- ASA- is accessible).
THANKS!
Overall Rating: 4 (2 ratings)
mmandel Tue, 10/09/2007 - 13:46
Why don't you just add your ASA to the OSPF routing process and make it a neighbor of the remote site router.
Mohamed Sobair Tue, 10/09/2007 - 15:17
How is your Default-route propagate it to the remote-site , Is it through OSPF or Static default-route?
If it's through OSPF, you can configure OSPF to Conditionally advertises a default route if the upstream Internet provider is accessible. and use another Static default-route with higher AD pointing to the Other ASA.
If you just have 2 Static default-routes on the remote site, then you can configure One Static-default route as primary & another Floating Static-route pointing to the 2nd ASA if the 1st ASA dies locally.
Mohamed Sobair
