TCP Timeout on backend sessions
We are using the CSS5-SSL-C-K9 module.
We use front-end and back-end ssl sessions for our https app.
i.e. :
browser -- ssl traffic -- sslrule -- K9cardfrontserver -- contentrule -- K9cardbackendserver -- realbackendserver.
We specify flow-timeout-multiplier 400 to avoid timing out the flows for the content rules.
But we still see the backend tcp session being closed after about 4-5 mins of idle i.e. server sleeps before response.
We do not want this to time out.
Any ideas what could be missing ??
Gilles Dufour Tue, 10/09/2007 - 23:40
the flow timeout command is for the css not to delete the flow.
But the SSL module as also its own timeouts.
CSS11503-2(config-ssl-proxy-list[gdufour])# ssl-server 1 tcp ?
inactivity-timeout Specify the server-side SSL TCP inactivity timeout
The default is 240 sec.
You can increase it to 3600 sec max.
The same command exist for the front-end connection.
Gilles.
