how to configure a "not match url" in a map in CSM 4.2.6
Oct 9th, 2007
Is there a way to configure a map with "not match protocol http url /abc/*"? read the docs, seems the special character '^' can do it but not very sure how to use it. Can some one tell me how?
Thx, Q.Xie
Gilles Dufour Tue, 10/09/2007 - 23:36
can't you try to reason the other way around ???
What should happen to traffic matching this url ??
Try to match this traffic first, and do a match all-the-rest for the rest of the traffic.
qixie Fri, 10/12/2007 - 11:11
Gilles, Thx for your reply. It will spend a lot of words to explain why I asked the question. I am a cisco employee. If it's ok to call you directly, I can explain the reason behind on phone. Could you just simply tell me if the CSM 4.2.6 has this "not match" option?
Thx, Q.Xie
