Priority Traffic Dropping
Oct 9th, 2007
We have the following QoS applied to a DS3 circuit out:
class-map match-all Voice
match ip dscp ef
policy-map WAN-EDGE
class Voice
priority percent 33
class class-default
fair-queue
random-detect dscp-based
policy-map shape
class class-default
shape average 1536000
service-policy WAN-EDGE
interface Serial0/0/0.1 point-to-point
bandwidth 1536
ip address x.x.x.x x.x.x.x
no ip redirects
frame-relay interface-dlci xxx
service-policy output shape
We are testing by generating voice and data traffic over the link using a packet generator (voice marked DSCP EF). When I run a "show policy-map interface serial0/0/0.1" during and after the test, it shows drops on the class-default and the voice class-map. Even when we send a very small amount of voice traffic it still shows drops in the DSCP EF queue. Shouldn't it only show drops on the class-default?
Overall Rating: 4 (1 ratings)
paolo bevilacqua Tue, 10/09/2007 - 16:37
  • Hall of Fame,
    Founding Member
Hmm.. seems like you want a nested policy but it become peculiar because it ends having has two class-default.
Please configure a simple priority for serial interface. It doesn't need to be shaped and nested as you can configure FR native parameters for shaping as frame-relay commands.
(that is, you only need nesting under shaping for interfaces where you have no congestion or backpressure, e.g a fastethernet where you want to send only a certain amount of traffic).
Verify results with packet generator and latency/jitter analyzer if available, then you can experiment modifications for different values, drop strategies, etc.
hope this helps, please rate post if it does!
