WebVPN Configuration help
Oct 9th, 2007
I was able to configure webvpn up to the point of login authentication. I have it set for LDAP authentication but can not successfully connect "login failed". is there a better way to get my users authenticated via webvpn?
Danilo Dy Tue, 10/09/2007 - 20:33
  • Blue, 1500 points or more
What LDAP are you using? MS AD/IAS?
Dandy
