SIP phone 3951
Oct 9th, 2007
Hi All,
We have been trying to get the SIP IP phone 3951 registered with CCM version 5.x but we are unable to do so.On the display of 3951 phone message is appearing Unprovisioned.
Since we are using SCCP phones which are working so, we tried to change Signalling protocol to SIP and manually added the phone in CCM . But still 3951 shows as un-registered.
can somebody help on same?
regds,
aman
AJAZ NAWAZ Wed, 10/10/2007 - 07:09
  • Silver, 250 points or more
My question would be will CCM support SCCP and SIP simultaneously?, You want to be able to do both right?
Ajaz
amansoi_5 Thu, 10/18/2007 - 22:26
HI ajaz,
I want to use both SCCP & SIP phones simultaneously...
Further, I have tried changing Auto Registration signalling protocol to SIP ( which is SCCP default) but SIP phone does not get registered.At same time, SCCP phones are working.
regds,
aman
AJAZ NAWAZ Fri, 10/19/2007 - 02:45
Aman,
It would appear that this phone supports SIP only.
"Q. What protocols are supported?
A. The Cisco Unified SIP Phone 3951 supports SIP at FCS. There are no plans to support Skinny
Client Control Protocol (SCCP)."
<http://www.cisco.com/web/CN/products/products_netsol/voices/products/3951/pdf/unified_sip_qa.pdf>
hth,
Ajaz
Pls rate this post if it helped.
amansoi_5 Fri, 10/19/2007 - 03:50
That's true.
My concern was for registration SIP with CCM 5.1 which is not happening.
regds,
aman
